| Subject |
Wastegates (physically aren't apt to go bad). Plus, |
| Posted by |
SirpriZ on April 08, 2014 at 2:42 PM |
This message has been viewed 332 times. |
| In Reply To |
Are my wastegate actuators bad? posted by rgonzales39355 on April 08, 2014 at 08:17 AM |
| Message |
you saw the arms moving when you put metered air to them. Try this: run a vacuum/boost reference from the intake, straight to the wastegate port. This completely bypasses your boost controller, and should let you know if the issue is at the wastegate(s). If you still have your safety boost solenoid online you should make around 9 psi, if the safety boost gizmo has been removed you should make base setting of 6-7 psi. Mark
| Follow Ups |
Post a Followup |
